Scale texure?
  • Scale texure?
    How does one scale a texture inside an imported vray material like Flooring Laminate E Narrow 250 cm?
    I wanted to do this simple task - but I simply can't figure out how to do that.
    Can anyone help?
    Jorgensen
    Yes, we can.
    The workflow would be: select the material in the Appearance Manager and tweak the Material Transform settings below: https://docs.chaosgroup.com/display/...erialTransform These will scale all the textures that are part of that material.
    In case you want to control them separately, you can do this using the Texture Placement options within the Asset Editor.
    Ana Lyubenova
    Product Manager
    www.chaos.com
