export vrscene
  • export vrscene
    hello,
    What-is the workflow to export a vrscene ?
    Thank you
    Hi Blizard ,
    The export button itself can be found after expanding the Render tab menu (see attachment). Are you going to import that .vrscene to Chaos Vantage or any other Chaos host app or you're going to send it to anybody?
    Best,
    Ana
    Ana Lyubenova
    Product Manager
    www.chaos.com
      Hi Ana,
      Thank you a lot for the answer, it's a little bit hide.
      Yes, it's for vantage
      Thanks again !
        You're welcome!
        Ana Lyubenova
        Product Manager
        www.chaos.com
          Ana, following up on the vrscene file... inside of 3ds max the displayed geometry for the cosmos assets placed in revit gets scaled incorrectly. Makes it extremely hard to use. See attached image, red is the outline of the building, yellow outline is the Revit Cosmos assets at a huge scale. The cosmos assets render at the correct scale, its just a viewport issue. Also, is there any way to get the "Compiling Scene Geometry" phase to compute faster in Max? Right now it takes 8 minutes before it finishes compiling.
            Hi cnd7jones ,
            The scaling issue you experienced is specific to V-Ray for 3Ds Max. We are aware of it and will attempt to fix it in a future release.
            As for your other question, most probably your scene is quite big. Though, I'd recommend asking in the V-Ray for 3Ds Max section of the forum.
            Best,
            Ana
            Ana Lyubenova
            Product Manager
            www.chaos.com
