Where is the chair model taken from? Apparently, it is a Revit family but where did the geometry came from? Was it built in Revit or imported from somewhere else?
The UVs are inherited from the host platform where they were set.
It will be beneficial to send us the .3dm file, if possible as a Packed Scene (V-Ray > Pack Project), of course if you are using V-Ray for Rhino.
If not - only the .3dm and the initially used textures.
You could upload the archive here or via our contact form. Just please add the forum link in the description.
If you import one Cosmos object and try to edit and replace its materials you may not meet issues, since the UVs are set correctly.
Sharing this as an example to try.
