no ies path in vray for revit
  • no ies path in vray for revit
    i do not know why there is no global setting for the ies path?
    no photo metric light path?
      The way photometric files are handled has been changed. Defining paths to them is not necessary anymore, so we removed them from the UI.
      Your V-Ray for Revit is working correctly.
      Ana Lyubenova
      Product Manager
      www.chaos.com
        However the light with photometric light ies can not be lit up when i rendered it ,I have been tried for many time ,still not work!
          1. Check the path to the photometric file in Revit.
          2. Select the lighting fixture and go to "Edit family", check if the light source is placed out of the lighting fixture geometry. If it is inside the geometry, move it out.
          Would be better if you can show us some screenshots or a video illustrating the problem. Otherwise we can only guess
          Ana Lyubenova
          Product Manager
          www.chaos.com
            Does the photometric web work if its inside a transparent/translucent/lightemitting material? Like a globe fixture? Or does it need to be outside of the geometry completely? Please clarify thanks.
              Yes, the photometric web works when placed inside a transparent/translucent/lightemitting geometry. Whether you place it inside or outside the lighting fixture geometry depends on your design intentions; it works in both cases.
              We've published a useful tutorial about lighting here: https://www.youtube.com/watch?v=JS-QFmyV3xQ
              Ana Lyubenova
              Product Manager
              www.chaos.com
                Wait a sec. Its that simple? How does Revit know know what "Future" means?
                ïîðòàë ïðîãðàììèñòîâ
                  Gorend39, can you please be more specific?
                  Ana Lyubenova
                  Product Manager
                  www.chaos.com
                    Does anyone have a view on how IES and PHPP softawe compare and what parameters drive any differences in the results?
