Vray for 3dsMax user here, investigating adding 3.0 to our Revit and SketchUp toolboxes. We got some trial licenses for both setup today. I need to better understand how Swarm is working (or supposed to).
Looks like the Swarm installer is built-in to the Revit & SU installers, but it is different versions. Revit appears to be Swarm 1.2 where SU is 1.3.4.
Is it the same Swarm between the two, ie can I just install 1.3.4 once from the SketchUp installer and it’ll work with Revit too (for render nodes without either host application)?
Autodiscovery doesn’t appear to be working on our network configuration, the swarm config page requires IP address –(sidenote: no chance for a hostname lookup)? Right now the only way I’ve been able to get multiple machines to show up in the localhost:24267 screen (regardless of which machine I try) is to manually specify a primary master node IP address. Any suggestions?
