Image map size on materials
  • Image map size on materials
    I have a floor tile set up in Revit as 24x48. When rendering in VRAY, that material shows up much larger. It seems to be the only material affected. Is there a setting I am missing?
    Does this material appear correctly in Revit? Can you provide screenshots?
    Or (even better) a sample scene containing that material so that we can test it here?
    Thank you!
    Ana Lyubenova
    Product Manager
    www.chaos.com
      Left is render in Revit (using Adesk360), right is render in V-ray. The carpet appears okay. The graphics on the glass is also missing. I don't get any path errors in Vray.
        I'm sorry, can you attach the images one more time because for some reason we are unable to see them.
        Thank you!
        Ana Lyubenova
        Product Manager
        www.chaos.com
ID:	954371 Let me know if this works
            Can you send us the scene so that we can test it in our environment?
            Is the text on the glass a decal? If yes, it is normal to disappear because we do not support decals yet.
            Please, PM me and I will explain you what we'll need you to send.
            Thanks!
            Ana Lyubenova
            Product Manager
            www.chaos.com
              How do i upload the scene without having to send revit file and all associated maps. They text is not a decal, it's just a material (similar to the blue graphics you see on the wall in background.
                We need the Revit file along with the associated maps for these 2 materials (the floor & the glass).
                In order not to send us the whole project, you can isolate only the floor and the glass in a separate Revit file and send it.
                Please, see your private messages (they are located at the top of the page on the right)
                Ana Lyubenova
                Product Manager
                www.chaos.com
                  sending revit file separately
                    Thank you!
                    Ana Lyubenova
                    Product Manager
                    www.chaos.com
                      Revit file
                        Hello Ana, ....are you still working on a solution?
                          Hi Tfquijano, please check your private messages at the top right corner of the page and respond my questions.
                          Thank you!
                          Ana Lyubenova
                          Product Manager
                          www.chaos.com
