Vray 3.4 Water Material
  • Vray 3.4 Water Material
    Did anyone save out the water material for 3.4? When I updated to 3.5 mind disappeared and the water in 3.5 is horrid.. for my uses anyway. Or if anyone has suggestions on how to recreate the water material from 3.4. The first image is 3.4 water, the second is wave water from 3.5 with the refraction removed for the closest visual to 3.4 as I can get. But as you can see it's no where close and doesn't look very good. Click image for larger version
Name:	13084_Rear Perspective hdr v2.png
ID:	962443Click image for larger version
    Probably this will help you: https://docs.chaosgroup.com/display/...terial+library
    Ana Lyubenova
    Product Manager
    www.chaos.com
      No I'm looking for the old material itself. When I go to my old project with the good water the .vrmat that was applied is just gone. It seems to have been deleted with the new version and all the new materials.
        Yes, this is because we updated the entire library. The older one is not optimized for 3.50.01. However, you can still use it after an update.
        The old library is available for download at the bottom of the page that I sent to you. There you will find the water you are looking for ; )
        Ana Lyubenova
        Product Manager
        www.chaos.com
          haha there it is. I missed that, thank you so much.
            You are welcome!
            Ana Lyubenova
            Product Manager
            www.chaos.com
