The ability to set CPU affinity (tell the V-Ray process it can use certain cores/cpus) to the Swarm process on nodes as well as the ability to set node availability schedules would make the swarm much better.
For instance, you can currently set the affinity of a node using Task Manager, but upon restarting the service or rebooting the computer, the changes are lost.
This would open up an alternative to having dedicated render nodes, and make it so you can use resources that either need some degree of usability while acting as a render node, or are only available during certain times (after hours, etc).
It was also mentioned in another thread, but we really need the ability to obtain a license when it's needed, and not automatically when starting Revit.
