V-Ray 5 for Rhino, update 1.5 is now available!
This topic is closed.
  • V-Ray 5 for Rhino, update 1.5 is now available!
    It can be download here:
    download.chaosgroup.com
    After installation, you will find more detailed info about the changes in the 'VRayForRhinoReleaseNotes' and the 'changelog' files:
    .\Chaos Group\V-Ray\V-Ray for Rhinoceros\VRayForRhinoReleaseNotes.html
    .\Chaos Group\V-Ray\V-Ray for Rhinoceros\changelog.txt
    Konstantin
    Installation
    • Chaos License Server updated to version 5.5.4
    • Chaos Cloud client application updated to version 1.12.0
    • Cosmos client application updated to version 2021.7.14
    Vision
    • Cubemap image export implemented. Select one of the new Camera Type options to enable it - VR Cubemap 6x1 or VR Cubemap 6 images
    • An issue sometimes causing an incorrectly lit patch (distorted rectangle) to appear in exported VR Spherical Panorama images is resolved
    Light Gen
    • A custom set of HDR images can now be used for scenarios generation
    • An option that allows for scene lights to remain active on scenario application is implemented
    • The custom Sunlight orientation is no longer modified when a HDR scenario is selected
    Asset Editor
    • Materials connected to an Attribute extension in another material are now correctly listed as sub-assets in the Outliner
    • Materials saved to a custom Library location before a valid preview image is generated now correctly use the default asset icon
    • Added support for OSL material and textures. Such can be loaded from a manually created vrmat containing TexOSL or MtlOSL plugins
    Integration
    • Missing Cosmos assets no longer cause a crash or prevent the render process initiation
    • An issue preventing V-Ray Library materials preview from appearing in the rendered Rhino viewport in specific situations is resolved
    • Rendering a region in the viewport (using RenderWindow or RenderInWindow) right after starting Rhino no longer leads to a crash
    • Changing the render engine while the interactive rendering process is running no longer leads to a crash
    • Modifying the Ground Plane's material no longer leads to a crash
    • All files required by the OSL compiler are now included in the V-Ray’s installation folder. TexOSL or MtlOSL plugins loaded from a manually created vrmat can now be rendered
    V-Ray Core
    • Proxy Meshes rendering is optimized leading to significantly shorter render times on machines with many cores
    • The VFB’s Display Correction mode now affects the history image thumbnails
