V-Ray 6 for Rhino, update 2.2 is now available!
This topic is closed.
This is a sticky topic.
  • V-Ray 6 for Rhino, update 2.2 is now available!
    It can be download here:
    download.chaos.com
    After installation, you will find more detailed info about the changes in the 'VRayForRhinoReleaseNotes' file:
    %PROGRAMFILES%\Chaos Group\V-Ray\V-Ray for Rhinoceros\VRayForRhinoReleaseNotes.html
    Regards,
    Konstantin​​​
    Improvements & bugfixes
    • Adaptivity Clamp control is introduced in the Render Parameters' Optimizations section. It can be used to avoid excessive sampling of overexposed areas.
    • Scatter Area Modifiers are now inactive when using '1D - On Splines' scattering mode to reflect that they have no effect on it.
    • Fixed an issue preventing Scatter's 'Normal Alignment' rotation option from accepting negative values. Scatter instances can now be aligned towards the vertical down (-Z) axis
    • Scatter guests with V-Ray Fur are no longer omitted from being rendered
    • Improved Scatter UV Grid surface mode handling of host objects with different mapping channels
    • Fixed an issue where Scatter's points previews are not drawn on the host's surfaces when Bounding box volume center guest origin is selected
    • Fixed an issue causing removal of V-Ray special objects from a Scatter's guest to delete all instance previews from the viewport
    • Added a 'Submit New' button to the Chaos Cloud window. Submitting multiple Cloud rendering jobs is now possible without having to close and reopen the window each time.
    • Fixed an issue preventing the Cloud window from reloading automatically after updated Chaos Cloud application
    • An issue causing updates of the Chaos Cloud application to produce errors is resolved
    • Implemented safeguard logic preventing V-Ray log files from reaching abnormal size
    • An issue causing an incorrect state of the Export button in the Export V-Ray Proxy window is resolved
    • Export V-Ray Scene window now always uses the current project's name in its File Path field
    • A valid default file path is now used in the Export V-Ray Proxy window
    • Export V-Ray Proxy window now consistently provides the same output file name when being opened multiple times
    • Fixed an issue preventing V-Ray windows from closing when opening a new project file
    • Fixed an issue causing the Animation Frame sliders to disappear in specific situations
    • An issue causing the V-Ray UI to crash in rare situations is resolved
    • Added support for edge softening adjustments during Interactive rendering in Rhino 8
    • Added support for Rhino 8 Blend materials
    • Added access to the Sun creation window via the V-Ray toolbar's Sun icon in Rhino 8
    • Added support for Rhino's native Clipping Plane inclusion and exclusion list in Rhino 8. A migration for preexisting scenes is implemented to ensure synchronization between the V-Ray and Rhino lists
    • V-Ray properties tab no longer appears empty in Rhino 8.3
    • Unassigned materials from vrscene files are no longer imported via the V-Ray Scene Importer
    • An issue leading to material loss when importing a linked block with other nested blocks is resolved
    • IES lights contained within Cosmos assets now produce the same illumination after asset merge
    • An issue producing artifacts in subsurface scattering materials when adaptive lights are used is resolved
    • The Environment Background multiplier now affects Sky texture's procedural clouds when rendered with V-Ray GPU
    • Rhino render resolution is now synchronized with V-Ray upon V-Ray activation
    • Grasshopper: Added viewport preview options for V-Ray Proxy Meshes, Proxy Scenes, and Cosmos Assets. The preview modes are: a simplified mesh, whole mesh, a bounding box or a point
    • Grasshopper: Instancer component plugged in an Infinite plane component is now considered for calculating the automatic Z Offset
    • Grasshopper: An issue causing data loss after upgrading Light Rig components from older versions is resolved
    • Grasshopper: Fixed an issue with incorrect Surface Scattering Slope Limitation and Slope Angles values in specific situations after upgrading Scatter components created with previous versions
    • Grasshopper: Fixed a crash when adding a Proxy Scene as a Scatter Guest
