V-Ray 7 for Rhino, hotfix 2 is now available!
This topic is closed.
This is a sticky topic.
  • V-Ray 7 for Rhino, hotfix 2 is now available!
    It can be download here:
    download.chaos.com
    After installation, you will find more detailed info about the changes in the 'VRayForRhinoReleaseNotes' file:
    %PROGRAMFILES%\Chaos\V-Ray\V-Ray for Rhinoceros\VRayForRhinoReleaseNotes.html
    Regards,
    Konstantin​​​​​
    Improvements & Bug Fixes
    • Added support for Rhino 9 (WIP)
    • A number of useful links are added to the V-Ray / Help menu - Chaos Academy, Chaos Forum, Support Request and Ideas Portal
    • The appearance of the Tri-Planar texture viewport preview is improved
    • ‘Make Unique’ and ‘Select Instances’ buttons are added to the V-Ray Properties panel of the Proxy Mesh, Proxy Scene, and Cosmos Asset
    • Texture Mapping size is now correctly updated during Interactive rendering
    • An issue preventing successful silent installation is resolved
    • A custom Viewport Texture bitmap is no longer set unnecessarily when migrating older scenes
    • An issue with the parameters of the vrayCosmos command is resolved. The Disconnect parameter is now correctly listed
    • An issue preventing Outline material attribute from working correctly when combined with a Translucency attribute is resolved
    • An issue with the uninstaller Quit page styling is resolved
    • The rendered appearance of Clearcoat of the Rhino Physically Based material is improved
    • An issue causing missing texture files when rendering RPC objects is resolved
    • An issue preventing rendering of specific .ply file containing Gaussian Splats is resolved
    • An issue leading to a crash after loading multiple projects in the V-Ray Batch Render panel is resolved
    • An issue leading to a crash when adjusting the Area Modifier parameters of Scatter during interactive rendering is resolved
    • An issue leading to a crash when accessing the Rhino Materials panel while Vantage is live-linked is resolved
    • Grasshopper: An issue preventing referencing a Cosmos material in the Material from File component is resolved
    • The Firefly Removal option is now hidden while the GPU engine is selected and greyed out while Progressive rendering is used, indicating that it has no effect with these configurations
    • A number of tooltips are updated
    • An issue preventing the submission of vrscene files for Cloud Batch rendering is resolved
    • An issue causing the Max Subdivs value to double when switching between CUDA and RTX GPU engine options is fixed
    • An issue causing the output resolution of Cloud Batch render images to be incorrectly overridden is resolved
