V-Ray 7 for Rhino, hotfix 3 is now available!
This topic is closed.
This is a sticky topic.
  • V-Ray 7 for Rhino, hotfix 3 is now available!
    It can be download here:
    After installation, you will find more detailed info about the changes in the 'VRayForRhinoReleaseNotes' file:
    %PROGRAMFILES%\Chaos\V-Ray\V-Ray for Rhinoceros\VRayForRhinoReleaseNotes.html
    Regards,
    Konstantin​​​​​​
    Improvements & Bug Fixes
    • An issue with migrating legacy projects is resolved. The fix primarily improves the migration of older projects and certain third-party asset libraries, such as Laubwerk’s
    • An issue where Swarm tags are updated unexpectedly due to an unstable connection to the nodes has been resolved. Tags are no longer removed without user interaction
    • The default output path in the Export V-Ray Scene window is improved
    • The Update Result denoiser button is no longer incorrectly disabled in a specific situation
    • All file paths displayed in the UI are now right-aligned to ensure the file name remains visible
    • Refresh button is no longer incorrectly displayed in the Cosmos asset properties header when selecting a variant that is not yet downloaded
