V-Ray 7 for Rhino, update 1 is now available!
This topic is closed.
This is a sticky topic.
  • V-Ray 7 for Rhino, update 1 is now available!
    This is a technical release that includes necessary backend changes, but it also brings a few new features and improvements you might find useful.
    It can be downloaded here:
    download.chaos.com
    Regards,
    Konstantin​​​​​​
    Improvements & Bug Fixes
    • Chaos Scans (VRscan materials) can now be loaded and rendered correctly without a Scans license
    • The entire Chaos Scans material library is now available in Cosmos
    • A new distributed rendering mode called Classic DR is implemented. Use it as an alternative to Swarm by manually configuring the network environment
    • Chaos Account management window is implemented
    • The handling of all license errors is improved
    • An issue preventing the standalone V-Ray denoiser from working is resolved
    • An issue with stopping a GPU render in a project where Caustics are enabled is resolved
    • The V-Ray installer now requires a CPU with AVX2 instruction set support to run
    • An issue causing Cosmos assets to render black when the global Material Override is configured in a particular way is resolved
    • The way Bongo keyframe animations are rendered is improved and optimised. The project is no longer reexported for every animation frame
    • Deleting or adding Rhino views during a live session is now correctly reflected in Vantage
    • Changing the size of a V-Ray Rectangular Light no longer affects its intensity
    • An issue causing discrepancy between CPU and GPU renders when Enmesh is configured in a particular way is resolved
    • Unnecessary render view updates are no longer performed during a live link
    • V-Ray for Grasshopper: The way the V-Ray Dome Light’s Rotation parameter is handled is improved. Texture rotation controlled by an V-Ray Texture Placement Environment component is now correctly handled
    • V-Ray for Grasshopper: An issue causing discrepancies in the camera view when using SpaceMouse Roll shortcut is resolved
    • An issue where the Chaos Sign In webpage would incorrectly open during V-Ray activation in certain cases is resolved
    • An issue causing error when opening the Asset Editor for the first time while a live Vantage session or interactive rendering is running is resolved
    • An issue preventing the Asset Preview rendering in specific situations is resolved
