Batch rendering interrupts with save confirmation
  • Batch rendering interrupts with save confirmation
    When batch rendering two or more scenes, the confirmation to save the Rhino scene is displayed and the batch is interrupted.
    Is there a solution?
    Confirm with Rhino5 + V-RayRhino, version 3.60.02 adv
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Bump!
    Nobody is here?
    oakcorp.net
    v-ray.jp
      Hello, and apologies for the delayed response!
      We were not able to reproduce the issue on our end. Could you please confirm whether you're using the latest Rhino 5 version (service release 14)? A screenshot of the Rhino Options > Files window (https://docs.mcneel.com/rhino/5/help...ions/files.htm) would also be appreciated.
      Kind regards,
      Peter
      Peter Chaushev
      Let's keep in touch
        It seems that it is a problem peculiar to Rhino Japanese version. [tested on Rhino 5 SR14 Japanese]
        In Rhoino Japanese version, the command "-_Open" determines the input value "No" as an unknown command.
        It is necessary to modify the Batch Render command which does not depend on the localized version.
        Click image for larger version  Name:	unnownkomanndo.jpg Views:	1 Size:	43.5 KB ID:	1001686
        oakcorp.net
        v-ray.jp
          Thank you for the additional info, we already have a solution devised for this particular issue. It will be included in v3.60.03 which is expected to be released soon.
          Kind regards,
          Peter
          Peter Chaushev
          Let's keep in touch
            Thank you for information.
            We are waiting for a fix update.
            oakcorp.net
            v-ray.jp
