Jagged curved edges
  • Jagged curved edges
    Hello everyone, I'm having an issue about curved edges, as they turn out jagged even if they are built as curves in Rhino; I'm not sure if this has to do with V-ray or Rhino though. Any idea on how to solve this?
    This is especially noticeable on sharp edges, see for example the upper part of the arch.
    this is due to the render meshes quality you set up in the settings.
    Try with smooth and slower, or if it's not enough you can use a custom setting.
    A smarter way to solve the issue could be to set a custom render mesh for the single object, leaving the default render mesh to jagged and faster, avoiding to waste polygons...
    select the object and go to proprieties, then tick custom mesh and click on adjust.. you can set the maximum angle to 20 deg or even less.. just try.
      Thank you so much! That solved the issue.
