automatic shift
  • automatic shift
    Evening,
    Is it only our versions that Vray automatic Shift is not working?
    VRAY for Rhino 3.60.03
    Best,
    Could you please elaborate what the issue is? A step-by-step description and screenshots would be appreciated!
        Originally posted by W_Alban View Post
        Evening,
        Best,
        Hi, it sometimes refuses to work, you can however count the shift manually by a basic math formula:
        vertical tilt = tg α = adjacent side / opposite side = height difference / target horizontal distance
        Cheers
        Jonas
          Is there an automatic? Only I know that there is a button and the command _vrayCamGuessVertical and the value is calculated and set at the camera.
            Try this: with the keyboard arrows, move up and back down to return to the original position, then press the guess shift button in the vray toolbar.
