Every time Rhino makes a backup, V-ray crashes while rendering in RT.
V-Ray Next crashes during Rhino autosave
Thank you for reporting this!
Could you please provide some additional info?- full version number of Rhino
- OS version
- list of 3rd-party plugins used (beside V-Ray)
- confirmation whether the issue occurs only with specific projects or is reproducible even with new scenes
PeterPeter Chaushev
Let's keep in touch
Hello,
Version 5 SR14 64-bit
(5.14.522.8390, 22/05/2017)
Win 7 Pro 64
Maxwell Render not in use.
It occurs more when working on heavy files.
When we stop the Render process, V-Ray unloads something and when Rhino makes the autosave in the same time, it crashes without notice.
BEst,
Alban
Further Problems occured:
- In V-Ray interactive mode, doing changes in texture mapping(UVW) Vray makes rhino crash.
- When pausing Int.-Mode, and making UVW changes, then restarting the Int.-Mode Rendering, changes are not applied.
- Setting the object display mode to rendered does show a black surface instead of the mapped texture.
I attach some screenshots of the mapping problem.3 Photos
Thank you for your reply! I will look into the mapping issue right away.
Regarding your initial report, Rhino 5 becomes unresponsive during autosaving and this period depends on the size of the project file. We were not able to reproduce any crash using a variety of heavy scenes.
Does the crash you described occurs every time during autosave while rendering Interactively or only on certain occasions?
Furthermore, could you please confirm whether the crash is reproducible while V-Ray is disabled? Simply open a particularly heavy project and use the _Autosave command.
Kind regards,
PeterPeter Chaushev
Let's keep in touch
Was not able to reproduce the mapping issues. The dark appearance demonstrated in your 3rd screenshot is due to the material's bump map. Our dev team is already onto it.
To further investigate the crashes you have described we can offer you live assistance. If this is alright, please send me a PM or an email at support@chaosgroup.com with your preferred time and date. My colleagues are available Mon-Fri, between 11:00-18:00 EET (https://www.timeanddate.com/time/zones/eet).
Kind regards,
PeterPeter Chaushev
Let's keep in touch
Originally posted by W_Alban View PostAnother one for the list.
When I copy paste a VRMesh of a Tree that worked fine in 3.6, to a new version of Vray Next, it crashes. If I copy the exact tree as a mesh it is fine.
Originally posted by W_Alban View Postthe "autosave -> crash" did somehow develop in an "autosave -> restart render progress" in progressive mode. also when I save manually V-Ray restarts rendering. Anyone same problem and solved it?
Kind regards,
Peter
Peter Chaushev
Let's keep in touch
I'm trialling Next at the moment and have had a couple of occasions where Rhino hangs. It seems to happen when I start an interactive render, I haven't noticed if autosave is involved. Rhino doesn't crash as such, it just won't do anything. Save doesn't work, even trying to Exit doesn't work. I've had to use Windows Task Manager to force Rhino to shut down. The file I'm working on it very simple, just a simple box with a ground plane (I was experimenting with the Metallic shader).
Rhino Version 6 SR13 (6.13.19058.371, 27/02/2019), Windows 10 Pro 1803 (17134.706).
Iain ,
Could you please advise how the rendering was initiated? Are you using the vrayRender or _Render command? Please be informed using Rhino's render command locks the interface and it is expected that if another command is executed, Rhino will be in a non-responsive state.
toniboni
Could you please advise if you are able to reproduce the issue consistently and whether this happens only with a specific project? Our dev team is interested in scenarios, such as the one you described. If you continuously experience this behavior, you could submit a report to support@chaosgroup.com
