VRAY NEXT - animation prepared in Bongo doesn't render
  • VRAY NEXT - animation prepared in Bongo doesn't render
    I have problem like in a title.
    I prepared a simple object animation in rhino using Bongo. After setting the animation and clicking "render animation" the vray frame buffer window appears, but the rhino stops and the "not responding" appears on the windows.
    What could be the reason for this? Everything worked in vray 3.6.
    I need to make a simple object animation - 360 rotation (but not the camera, only the object)
    Could you help me?
    Hello, Krystian,
    I was notified my colleagues from the Support team are already in contact with you regarding this issue.
    If anyone else encounters a similar problem, please send a description of it to support@chaosgroup.com together with a project file for further investigation.
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
      Hi Peter,
      That's right, but the problem has not been solved yet. TeamViewer is planned
      Krystian
        Hi, I was wondering if there is direction on this issue. As I am having the same problem. Thanks in advance.
