VfR4 at multi task Rhino
  • VfR4 at multi task Rhino
    some times I open a new Rhino task and can't open the VfR UI. The UI is empty.
    -Micha
    Hi Micha
    Could you please provide a step-by-step description how the issue is reproduced? Is a specific project loaded and then you open a new Rhino file from the menu or Rhino's application icon?
    Additionally, could you please advise what GPU model you are using and its drivers version?
      Hi georgi.georgiev
      today I got my new GTX2080ti and so I installed the current driver - I can't repeat the issue, but if I see it again, than I will look for a way to repeat it.
