Dear ChaosGroup,
I'm have the latest Vray next (hotfix 1) for Rhino 5 and have been having this irritating problem with the Region render in the Frame buffer.
Here's the description.
I usually save my final renders with the history window in the Frame Buffer. If I have to make changes, I load the render and do a region render on a selected part of the image.
Here's the problem, Immediately after saving the render in the history window and do a region render, it works fine. But if I close rhino after saving it in history, open the rendered image and then do a region render, it never does it in the first try..... it always renders the 'entire scene' again. Only when I stop it, load the scene from history again and then do a region render, will it render the region. It is never in the first try!
Could you please check and provide a fix?
Thanks
Bomching
Thanks
Bomching
