How to disable the effects result channel?
  • How to disable the effects result channel?
    I tested the lens effects at my current, but decide me not to use them, but the effect result channel is still at the frame buffer and saved, if I use the multi save button. If I disable the denoiser, than I don't get the unwanted effect channel. Looks like a bug or?
    -Micha
    There is no way to disable effectsResult channel from being created if the image is being Denoised, there’s a Lighting Analysis render element or Lens effects applied. You would have to manually remove the channel image file afterwards.
    In the upcoming update using the VFB "Save Current Channel" button will not append the channel name as a suffix to the produced image file name.
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
      I don't enabled the lens effects or the light analysis, but still get the effectsResults. Could it be avoided? It fills the hard disk, but isn't wanted.
        This cannot be avoided if you have enabled the Denoiser or any of the other effects I mentioned.
        Kind regards,
        Peter
        Peter Chaushev
        Let's keep in touch
          OK, I understand.
