Can't install V-Ray Next for Rhino
  • Can't install V-Ray Next for Rhino
    I tried to update V-Ray Next for Rhino but the checkbox for Rhino 6 is greyed out in the installer. I uninstalled V-Ray, restarted the computer and tried again but the option for Rhino 6 is still greyed out. The V-Ray version I am trying to install is 4.10.02. I have Rhino 6.8.18 installed.
    A little follow-up: I use an EDU license. I can no longer see under DOWNLOADS where to download the EDU installer. It only allows me to download the ADV version.
    EDIT: by changing the URL to "license_type=edu" I was able to access the EDU downloads (will this be addressed, Chaos Group?) but even with that installer, I can not check the box for Rhino 6.
    ANOTHER EDIT: Problem RESOLVED. As it is 99% of the time, it was user error not V-Ray - Rhino decided to do a ninja update to 6.21 when I opened it up for the 100th time and now the installer for V-Ray appears to be working.
      There are no more EDU builds, we left only 1 build in the download sections that works with all available licenses.
      There is a message in the installer that tells you which is the minimal required Rhino version (in case the option is greyed out), so upgrading Rhino is the solution in such cases.
      Ivan Slavchev
      SysOps
      Chaos Group
        hi,
        I tried to install V-ray Next for Rhino, update 2.2, and in the phase of installation parameters, install V-ray 4.20.03, I can't press on the anyone of the option of rhinoceros 5/6/7.
          Hello, and apologies for the late reply!
          Please check the system requirements for V-Ray Next for Rhino: https://docs.chaosgroup.com/display/...m+Requirements
          You need either Rhino 5.14 or Rhino 6.23 to install V-Ray.
          If all options are grayed out this usually means no compatible Rhino version is found on your system.
          Regards,
          Peter
          Peter Chaushev
          Let's keep in touch
