Hello,
it appears the V-Ray for Rhino plugin conflicts with Rhino's 'PrintDisplay' command.
Draw a line, set its print width to "no print" in object properties. Then toggle 'PrintDisplay' status on and off.
V-Ray Plugin deactivated: the line disappears as it should.
V-Ray Plugin activated: the line still shows. Essentially the 'PrintDisplay' command is corrupted by V-Ray.
I just saw this had previously been brought up here: https://discourse.mcneel.com/t/print...y-loaded/87435
I use V-Ray for visualisation and "no print" line width parameters for help geometries when drafting production plans. It is thus very cumbersome having to enable/disable the plugin and restarting all Rhino instances every time when you want to switch from one task to the other. It's especially troublesome since running a rendering is usually a background task whilst I want to generate plans.
My V-Ray version is currently back to v3.60.03 adv (Jul 3 201
, although I've had the same issue with the newer v4 update.
Thank you for helping.
