Poor renders in parallel view
  • Poor renders in parallel view
    Hello again, second question of the day as I have found another problem. When I try to render in a parallel view port, the render comes out highly distorted and pixelated. I have attached a image of the final render. You can notice this problem throughout the render and on the curved topography line. Any idea on how to fix this? Same distortion appears on every file in a parallel view.
    Below is the Rhino Render view port so you can compare to the vray render output above. Looks a lot better and it is not even completely rendered through! I am running Rhino 6 with Vray Next.
      You mean the texture is wrong shown, right? Do you use the CPU or the GPU mode?
        Hi whacer,
        Please share a scene so that we can test on our side.
        It can be a stripped down version.
        Thank you in advance,
        Konstantin
