I noticed that the Vray Renderer for Grasshopper silently fails if you don't provide a valid file path for the "Out Img" parameter. If you have nothing connected it works fine. If you have a valid file path connected it works as well. But if for some reason you connect an invalid file path, say a relative file path, the renderer opens and just does nothing without giving any indication why.
Normally in Grasshopper the renderer would turn orange or red and give an error description. I also tried to open the Vray message window and that does nothing on the Grasshopper renderer. Once again on the Vray render window launched from Rhino I can open the messages window, but not in Grasshopper.
Check the attached .gh file in the zip.
