Bump + Bump issue during RT
  • Bump + Bump issue during RT
    per VfR5 we got a bump slot at the VRay Mtl layer and a extra bump slot can be added. I started a interactive rendering and set a round edge texture at the Vray Mtl -> is shown. I added an extra bump slot and the round edge was gone. I found, the RT needs to be restarted to get both bumps effects shown. Maybe this little issue can be fixed.
    (I'm glad to see that it finally works to combine a bump tetxure with round edges in one material. Thank you.)
    Maybe it's the same bug:
    * create an emissive material, add a texture and start an interactive rendering -> OK
    * add a reflective coat -> short black rendering and than OK
    * add a bump slot -> rendering not OK, material grey
    * delete reflection coat -> material black
    * delete bump -> rendering OK
    So, there seems to be an update issue during RT (at the frame buffer tested).
      Thanks for letting us know.
      I'll retest and log all the issues described.
