Disabled cast shadow not working if translucency is added (GPU issue)
  • Disabled cast shadow not working if translucency is added (GPU issue)
    I try to setup a lamp and I found, that the disabled cast shadow isn't working if "translucency" is added to a material. I hope it can be fixed and both used together.
    -Micha
    Hi Micha, thanks for noting this. Our devs will have a look and we'll let you know the outcome.
    Nikoleta Garkova | chaos.com
      This is now logged under WEBUI-5711 in our internal bug-tracking system. If you do it the other way around (first add Translucency attribute and then add and adjust the Raytrace Properties, it should work as expected. Thanks for the pointer.
