the _vrayRenderWindow is great, thank you for adding it. Could this command not be used for the RMB click on the render button per default? I suppose so this is the more needed use. (OK, I can manually change it here but every new release will destroy my button change. In the past at VfR2 this function was standard, so it could be the default RMB function here.
I ask me could it be avoided that the frame buffer is cleared before a region of the viewport is rendered? It would be the more safe way to leave the frame buffer content untouched. If needed the user could clear the frame buffer by the frame buffer "clear image"button.
-Micha
-Micha
