Custom sun orientation is working? ... and some more questions
  • Custom sun orientation is working? ... and some more questions
    I didn't used the sun&sky system since a very long time and so I'm not sure how to use them. Some things I don't understand. I was able to use the Rhino document sun.
    • * Is it possible to use other dir lights as sun too? I tried it but don't got it working.
    • * The V-Ray Sky options allow to enable a custom orientation, but it doesn't show an effect. Is it supported? How to use them? (The Rhino sun manual control works.)
    My goal would be that I have a few Skies saved so that I can enable an adjusted setup for different view.
    At the help page I read "Intensity Multiplier – Affects the brightness of the sun...", but the slider seems to control the brightness of sun and sky together. It'ss ok, but could be correct noted at the help page. Also I found that the diffuse/specular slider control the sun only, not the sky light. That's fine too, but should be noted at the help page too.
    Also I found no way to disable the visibility of the sky ground. The Albedo color is visible always. Could be good if a disabled visibility would turn off sky, sun and ground.
    (All tests done in GPU mode.)
