Vray-5 | Problems applying materials to vray fur objects
  • Vray-5 | Problems applying materials to vray fur objects
    Hi everybody.
    If i set some default material library material to fur object, and i start a render this is the result. If i set a default material there are no problems. If i start an interactive render there are no problems. There is this problem only in the production/progressive mode.
    I had this problem since the new version 5. I'm using rhinoceros 6, with a 1070 ti.
    Hello BossFx
    This Issue has been logged in our system - ref num 2986
    As a workaround please use Full-size textures or Resize textures options under the GPU Memory Management menu.
    Click image for larger version  Name:	Image_GPUManagement.png Views:	0 Size:	19.3 KB ID:	1100190
      Originally posted by slavcho.brusev View Post
      Hello BossFx
      thankyou very much, i will try.
      meanwhile i'm using a generic material with the same texture (i have opened the .tx texture from chaosgroup library, converted into a jpg)
        A solution for this problem has been devised. It will be included in the next V-Ray 5 for Rhino update.
        Kind regards,
        Peter
        Peter Chaushev
        Let's keep in touch
