Black rendered material using GPU
  • Black rendered material using GPU
    Hello Everyone,
    I´m getting a black Render of the Proxies that I scattered with GH when using RTX or CUDA. When I´m using CPU mode it works fine.
    The assets that are rendering correct are not scattered with GH. I referenced the Material to the Proxies with the solution provided to me in my previous post by creating my own multimaterial.
    Any Ideas what I could change?
    Hello,
    Thank you for reporting this!
    I have created a ticket in our internal system(ID number VGPU-5341) so our developers can further investigate. Unfortunately I didn't find any workaround except using the CPU engine.
      Hi alexander_albiez,
      All the setups that I described in the other post actually work for me (both on CUDA and RTX):
      https://forums.chaosgroup.com/forum/...-be-referenced
      Here's the result with an instancer:
Name:	renderInProject - instancer.jpg
      And the other approach - instancing the Proxy Mesh itself:
Name:	renderInProject - instancedProxy.jpg
      Can you share a simple example of your setup so that I can see what's wrong in it?
      Konstantin
