V-Ray tasks doesn't stay in the Rhino task at the taskbar
  • V-Ray tasks doesn't stay in the Rhino task at the taskbar
    An old problem is back - each V-Ray modul gets an own task bar entry. I hope it can be fixed again.
    (Win10(1909(18363.1316))|Rhino7|VfR5)
Name:	Screen Shot 03-03-21 at 04.27 PM.JPG
    I think that you can just group the taskbar buttons from the Taskbar Settings:
    Konstantin
      No, I need the labels and i don't want to group all open Rhino tasks. It was working in the past after a fix was applied. Now the issue is back. It could be nice to get the fix again.
        Hum, I'll talk to the devs and get back to you.
          Hi Micha,
          Could you please check if environment variable VRAY_WINDOW_NO_COMBINE is defined.
            nikolay.bakalov The variable wasn't defined. I did it and set it 1. Restart Windows. It doesn't work. Set it 0 and restart - it doesn't work.
              You must not have this variable defined at all, not 0, not 1, nothing at all
              When this started to happen ?
              Your post is from March 3rd, did it work before ? with Update 1 ?
              I'm trying to figure out if this is a result of an external reason (windows update, rhino update), or it was from our code
              I can't reproduce it on 2 machines, can someone else try ?
                Sorry, I don't know when it started. It can be since some time.
