Decals issues - multiple decals with same material
  • Decals issues - multiple decals with same material
    Today I work with decals and found strange issue.
    If I set 2 decals on #1 object and another decal on #2 object with same V-ray material, the decals starts to interfere.
    I can only see one of them at time. Tried several workarounds (moving, scaling decals, checking bacward-forward projection, delete and create object again and so) but for now it works only if I duplicate material and apply its copy to object.
    I observed it also with one interior project with decals at wall paintings.
    Here I record the video: https://streamable.com/r795zw
    Hi pavol_pastork
    I've managed to reproduce this and it is now logged under VRW-3149 for developer investigation. We will let you know when there are any updates on the matter.
    Meanwhile, you can make duplicates of the materials and make sure to assign different materials as a workaround. Thanks for the pointer!
    Nikoleta Garkova | chaos.com
      Hi pavol_pastork,
      This issue should be fixed in the latest update - V-Ray 5 for Rhino, update 1.2
      Konstantin
        Hi konstantin_chaos it works. thanks
