No Way to control Sun created with the previous version on the Light Mix
  • No Way to control Sun created with the previous version on the Light Mix
    Hi Guys
    I'm using the V-Ray 5.1.1 and all my Rhino suns from the previous version do not appear or I can not control it using the light mix.
    In the attached image you will see that all the lights including the sun is disabled and I still have the Rhino sun in the scene.
    Hi javierrentas
    Apologies for the delay and thank you for reporting this. We were able to reproduce this on our side as well and it is now logged under VRW-3190 in our internal system for developer investigation. We'll let you know when there are any updates on the matter.
    Nikoleta Garkova | chaos.com
      Thank you! I had lost hope!
        Hi javierrentas,
        Just to inform you that a fix for this issue should be out with a future update. Thanks for the understanding and patience!
          Thank you! I really appreciate your effort
            Hi javierrentas,
            This issue is fixed in V-Ray 5 for Rhino, update 1.3
            Konstantin
