Right, since nearly all the intensity is below 1 you don't get a glow. Try a lower intensity [EDIT: I mean threshold] than 1 and you will see a glow. The problem of your setup is that you don't have intensive bright areas and it will work better and looks nicer if you have it.
Thank you! Micha
Still why there's no difference between enabling and disabling the Bloom/Glare function?! And why there's no reaction to my adjustment now?! Some aren't giving the possibility to adjust at all.
Set the threshold below 1. 1 means pixel value 255 in 8bit. It looks like your image has no large dynamic. Maybe the brightest pixel is around 1 only. All pixel above the threshold will be processed. So, if you set it 0.1 than you should see an effect.
