I am attempting to blend two materials together, namely VRay's Gravel_A01_80cm with Sand_C01_500cm. While the blend preview looks okay, the actual surface itself is only calling the base material, Gravel.
Blend mode not working with VRay Sand and Gravel texture
Hi james_churchill,
The viewport texture does not affect the way the material is rendered with V-Ray, so upon rendering everything should be fine. The way it is showing in the viewport is mainly used for preview purposes. You can also change that from the material's Binding option.Nikoleta Garkova | chaos.com
