I'm trying to reference a "Material From Project" into Grasshopper but it's causing an error in the "Render In Project" component. I've tracked it down to a radial gradient "Texture Map" that I'm using in the Anisotropy Rotation texture slot (I don't like to use a bitmap here as this always seems to cause a line where the gradient 'steps' back to white from black no matter what resolution I use).
I know that previously the spline curve didn't work in grasshopper, but having done a quick test it seems that all texture types are now working through Grasshopper except for the Gradient which is causing the attached error.
