Second level of Bump Multiplier wont work with GPU
  • Second level of Bump Multiplier wont work with GPU
    Hi Guy
    When I try to use a second or even a third level of bump, the multiplier (Amount) wont work. This is very critical for us, since we changed to GPU rendering and spent a lot of money on hardware.
    Here is quick video explaining my issue.
    https://www.screencast.com/t/HPZLWvzkfEwy
    Please, can you add support for this on the next build?
    Thank!
    Hi javierrentas,
    Thank you for the pointer - we've reported this under VRW-3387 and we will let you know when we get any updates from our developers.
    In the meantime, you can use Blend Material as a workaround to achieve multiple layers of bump, which you can control via the blend amount slider.
    Nikoleta Garkova | chaos.com
