Bug: Soft shadow of dir light not working in GPU mode anymore
  • Bug: Soft shadow of dir light not working in GPU mode anymore
    .. in BF and LC mode. Please try to build a quick fix release, since it's an essential feature. I use the dir light daily.
    -Micha
Name:	Screen Shot 11-21-21 at 07.37 PM.JPG
    Hi Micha,
    Thanks for the pointer. This is now logged under VRW-3486 for developer investigation.
    We'll let you know as soon as we have some input on the matter.
    Nikoleta Garkova | chaos.com
      I hoped it's a little bug only and quick fixed, since it's an essential feature ... but it's not fixed at the current update. Please don't forget them.
        Yes, the bug remains and is quite serious.
        Thanks for the reminder!
        I'll raise its priority.
          konstantin_chaos The last update doesn't fixed it again.
          Today I found that the shadow softness isn't complete out of order, it seems to be a scene unit related problem. If I use 'meters' and set a very high shadow radius than I get a blur effect. But if I use centimeter or millimeter than I can't raise the slider high enough, since 10 is the limit. Please, allow to set a higher radius values as a workaround until the bug is fixed. Better a soft shadow by radius 1000 than no soft shadow.
            One of the problems is a rotational matrix normalization. Having bigger units tend to make the rotational matrix "look" more normalized. You basically hit an edge case for which it kind of works, but that's not the whole thing
              Still hoping a fix will come soon. My old scenes doesn't work anymore.
                This is what's currently in the dev branch (so it has been fixed and will be available soon):
                Click image for larger version  Name:	shadow_radius.png Views:	0 Size:	226.4 KB ID:	1140190
                You have a simple workaround in 5.20.04, although a bit cumbersome
                Place the position of your directional light at a distance of 1 unit from its target - this has a side effect of producing normalized matrix. It is not pretty, but will work for the most part
                Click image for larger version  Name:	shadow_radius_52004.png Views:	0 Size:	318.6 KB ID:	1140191
                  I did a quick test and the workaround works.
                  Thank you very much.
                    Please don't modify your original scenes for good, we will be having this released soon.
                      Hi Micha,
                      This issue is fixed in the latest update - link.
                      Konstantin
