Duplicated materials still interlinked
  • Duplicated materials still interlinked
    Hello,
    Using the current V-Ray 5 I've created my Blend material and duplicated it five times to use different coat mask each time. Coat masks stay connected so no matter what I do, I can even delete the texture in the slot, when I assign a new one, the change applies to all duplicates of the original Blend material.
    Jonas
    Imho deep copy / shallow copy misuse in the code.
      Hi Jonish,
      I did some tests but couldn't reproduce the issue you describe.
      Can you please list the exact steps you take to cause the problem?
      Thank you in advance,
      Konstantin
        Hi Konstantin,
        1. Create 2 bitmap textures, material Blend1 with base and coat material. Set Bitmap1 as coat blend texture (paste as instance).
        2. Duplicate Blend1 material and in the new Blend2 material set Bitmap2 as coat blend texture (paste as instance).
        3. Voilá! Blend1 material's coat blend texture has changed too.
        This happens to all duplicates of one original blend material, i.e. it cannot be duplicatedand edited afterwards. All individual blend materials have to be created by hand.
        Is it working now?
        Jonas
          Hello, Jonas,
          Thank you for describing this issue!
          Just wanted to update you that Konstantin logged the bug for further investigation. A solution is scheduled by our dev team for the next update.
          Peter Chaushev
          V-Ray for SketchUp | V-Ray for Rhino | Product Specialist
          www.chaos.com
            Thank you Peter!
            There's also another bug we're currently struggling with, as a lighting sculpture designing company, heavily relying on blocks:
            https://forums.chaos.com/forum/v-ray...nation-channel
            Have a great day
            Jonas
