Rendering Quality
  • Rendering Quality
    I am rendering an iamage. I adjust the quality to high+. However, the image is still vague. Does anyone know how to deal with it?
    Thank you.
    The quality of the image is not a problem, you should be concerned by other things. Look online for some reference photos of building like your, then try to understand the difference with your render
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
      Originally posted by ziyao_zhang View Post
      Noise limit at 0.03 and denoiser enabled should create a clean image. Noise limit at 0.01 can be used without denoiser, but it's much slower. For more speed you could try 0.05 + denoiser.
Name:	Screen Shot 12-17-21 at 08.06 PM 001.JPG
        Originally posted by sirio76 View Post
        The quality of the image is not a problem, you should be concerned about other things. Look online for some reference photos of buildings like yours, then try to understand the difference with your render
        Thank you for the suggestion.
          Originally posted by Micha View Post
          The noise limit at 0.03 and denoiser enabled should create a clean image. The noise limit at 0.01 can be used without denoiser, but it's much slower. For more speed, you could try 0.05 + denoiser.
          Thank you.
            I still have a problem with quality. The picture shows the rendering setting.
            Thank you.
              Disable the antialiasing filter and enable the denoiser.
                Hi ziyao_zhang,
                Another thing I'd consider is rendering a bigger resolution image.
                You will see a much crisper result this way.
                The image can then be downscaled in post if you specifically need a smaller image.
                Konstantin
