Vray plugin for rhino not working.
  • Vray plugin for rhino not working.
    I had Vray for Rhino successfully installed and when I went to use it today I received the following error message upon opening rhino:
    error loading vrayforrhino.rhp plugin
    I uninstalled and reinstalled vray three times without any luck. The message keeps popping up upon every installation. I checked I was using the latest vray exe and my rhino is up to date as well. I can't find the .rhp file anywhere.
    Try the following:
    Go to C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7 or V6(depending on your Rhino version) and drag and drop the VRayForRhino.rhp into the Rhino's viewport.
      This worked, thank you so so much!!!
