After extending my V-ray license and updating to the latest version, I'm no longer able to GPU render. When I attempt to GPU render, I am given this error message:
The Extended Log is as follows:
[09:14:28.694] V-Ray Frame Buffer message log initialized
[09:14:28.770] Loading plugins from "C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\vrayappsdk\bin/plugins/vray_*.dll"
[09:14:28.826] 78 plugin(s) loaded successfully
[09:14:28.826] Finished loading plugins.
[09:14:29.020] GI engines: 'Brute force' and 'Light cache'
[09:14:29.020] Warning : SettingsRTEngine::gpu_light_cache is deprecated. Light cache is always calculated on the GPU when V-Ray GPU is used for rendering
[09:14:29.020] Preparing renderer...
[09:14:29.569] Creating bitmap manager
[09:14:29.569] Bitmap manager created.
[09:14:29.569] (100.0%)
[09:14:29.569] Light tree is enabled with clamp coefficient 0.1 and even split coefficient 0.5.
[09:14:29.570] CUDA renderer requested.
[09:14:29.570] CUDA renderer plugin already loaded.
[09:14:29.570] CUDA renderer plugin instance successfully created.
[09:14:29.570] EXT_RTOPENCL interface obtained successfully from CUDA renderer plugin instance.
[09:14:29.571] Using low thread priority.
[09:14:29.571] Max ray intensity is enabled: rendered result may have incorrect brightness.
[09:14:29.574] (0.0%)
[09:14:29.636] (100.0%)
[09:14:29.636] (0.0%)
[09:14:29.637] (100.0%)
[09:14:29.637] Using Embree ray tracing.
[09:14:29.637] Scanning scene for light plugins.
[09:14:29.637] 1 lights found.
[09:14:29.637] Using adaptive light evaluation with 8 lights.
[09:14:29.647] Using 1.60 MB for adaptive lights buffer
[09:14:29.647] nVidia driver version: 466.11
[09:14:30.220] Querying for CUDA devices...
[09:14:30.359] PTX file generated with CUDA Toolkit v10.0 for CUDA compute capability 3.0.
[09:14:30.502] Compiling OptiX with full optimizations.
[09:14:30.502] Device[0]: NVIDIA GeForce RTX 3080 (WDDM mode) has compute capability 8.6. PCI Bus ID: 0000:01:00.0
[09:14:31.161] (0.0%)
[09:14:52.006] (100.0%)
[09:14:52.037] Error : [VUtils::VOptix::OptixModuleCreateThread::createMod ules] 9059: OptiX Module compilation with task failed. Module compilation state 9059
[09:14:52.039] Running RTEngine
[09:14:52.039] Warning : Cancelling GPU rendering!
[09:14:52.039] Number of raycasts: 0 (0.00 per pixel)
[09:14:52.039] Camera rays: 0 (0.00 per pixel)
[09:14:52.039] Shadow rays: 0 (0.00 per pixel)
[09:14:52.039] GI rays: 0 (0.00 per pixel)
[09:14:52.039] Reflection rays: 0 (0.00 per pixel)
[09:14:52.039] Refraction rays: 0 (0.00 per pixel)
[09:14:52.039] Unshaded rays: 0 (0.00 per pixel)
[09:14:52.039] Peak memory for frame 0: 97.99 MiB collected for 22 categories
[09:14:52.039] Peak memory for "Bitmap": 0 B
[09:14:52.039] Peak memory for "Bucket image sampler": 0 B
[09:14:52.039] Peak memory for "Dynamic displaced geometry": 0 B
[09:14:52.039] Peak memory for "Dynamic geometry": < 1 MiB
[09:14:52.039] Peak memory for "Dynamic moving displaced geometry": 0 B
[09:14:52.039] Peak memory for "Dynamic moving geometry": 0 B
[09:14:52.039] Peak memory for "GI": 1.76 MiB
[09:14:52.039] Peak memory for "Lights": 0 B
[09:14:52.039] Peak memory for "Misc.": 87.92 MiB
[09:14:52.039] Peak memory for "Misc. displaced geometry": 0 B
[09:14:52.039] Peak memory for "Misc. geometry": < 1 MiB
[09:14:52.039] Peak memory for "Misc. moving displaced geometry": 0 B
[09:14:52.039] Peak memory for "Misc. moving geometry": 0 B
[09:14:52.039] Peak memory for "Progressive image sampler": 0 B
[09:14:52.039] Peak memory for "Static displaced geometry": 0 B
[09:14:52.039] Peak memory for "Static geometry": 0 B
[09:14:52.039] Peak memory for "Static hair": 0 B
[09:14:52.039] Peak memory for "Static moving displaced geometry": 0 B
[09:14:52.039] Peak memory for "Static moving geometry": 0 B
[09:14:52.039] Peak memory for "Static moving hair": 0 B
[09:14:52.039] Peak memory for "Tiled bitmap": 0 B
[09:14:52.039] Peak memory for "VFB": 8.26 MiB
[09:14:52.039] Number of light evaluations: 0 (0.00 per pixel)
[09:14:52.039] Maximum memory usage for resman: 0.00 MB
[09:14:52.039] Number of intersectable primitives: 0
[09:14:52.039] SD triangles: 0
[09:14:52.039] MB triangles: 0
[09:14:52.039] Static primitives: 0
[09:14:52.039] Moving primitives: 0
[09:14:52.039] Infinite primitives: 0
[09:14:52.039] Static hair segments: 0
[09:14:52.039] Moving hair segments: 0
[09:14:52.040] Cleaning up bitmap manager
[09:14:52.590] Maximum memory usage for texman: 0.00 MB
It doesn't matter what I try to render, in this instance I have just attempted to render a simple box, and the render has failed.
I am running a build with a AMD Ryzen Threadripper 3970X 32-Core Processor, 64GB ram and Nvidia GeForce RTX 3080. I have run VRay for Rhino on this build over the last year and had no issues GPU rendering until recently.
I'm not quite sure what the fix is for this, but any help would be great.
Thanks!
1/31/2022 9:14:52 AM | Error | [V-Ray] [VUtils::VOptix::OptixModuleCreateThread::createMod ules] 9059: OptiX Module compilation with task failed. Module compilation state 9059 |
Thanks!
