Error [V-Ray] [OOCRenderThread::syncStream] 700: Stream sync failed
  • Error [V-Ray] [OOCRenderThread::syncStream] 700: Stream sync failed
    I'm working on a complex scene in RTX mode and during the LC is calculated endless error messages popup. Is this a known problem?
    The scene was rendering fine and without problems the last days.
    -Micha
    18.2.2022 16:50:43 Error [V-Ray] [OOCRenderThread::syncStream] 700: Stream sync failed
    18.2.2022 16:54:10 Error [V-Ray] [MemoryManagerGpu::releaseUnmappedMemoryFromInstanc e] 700: Could not release device buffer
    Try restarting Rhino than GPU Driver update. If that doesn't help please send the project for us to review by using the "request" link below.
    https://support.chaos.com/hc/en-us/requests/new
      I use the latest recommended GPU driver. Would it be good to use a newer one?
        Not really, we didn't upgrade it to the new one because of performance issues
        Muhammed Hamed
        V-Ray GPU product specialist
        chaos.com
          slavcho.brusev At your request link I wasn't able to choose a reason like "bug report" and so I wasn't sure it's the right place. I decided me to sent a bug report per email and the ticket number is 24072. Is it ok too?
          I found that the error happens in non-progressive mode only, in progressive RTX mode it works. Also the error isn't shown at every camera location, only in the near of the door.
Name:	Screen Shot 02-19-22 at 09.33 AM.JPG
            Finally it helped to reset the global V-Ray options of the Rhino file. No big task and no error appears anymore.
              Thanks Micha!
              I will forward the bug option request to our team here.
