edges continuity doesn't work
  • edges continuity doesn't work
    I'm trying to use displacement from grasshopper but the option "edge continuity" doesn't work. it's a bug? a limitation? Click image for larger version
Name:	Vray grasshopper displacement bug.PNG
    Hello,
    I am reproducing this on my side as well. It is reported under VRW-3601
    I have not found a workaround yet. If I find one I will write here.
      thank you Slavcho, it's important to find a solution for us
        Hi
        Is this happening the same with Vray gpu 5.2 for sketchup??
        Thanks in advance
          I don't know in SketchUp.
          Do you have any news Slavcho?
            This is a issue only in V-Ray for Grasshopper, because the exporter is not setting an important property.
            It is already fixed, and will be available in the next update
              Hi Nikolay!
              thank you for your reply. Do you already have an idea about when approximately it will be available the next update (only to organize better our work)?
