rhino commands that can be moved, such as save, cannot be used
  • rhino commands that can be moved, such as save, cannot be used
    Hello, I have a small problem. When I was using Vray for Rhino, I had several small bugs. At that time, I accidentally stopped rendering after clicking the render button, the interval between these two clicks was very short. Only rhino commands that can be moved, such as save, cannot be used. I'm not sure it's the software, but I remember this problem with older versions of Rhino and Vray.
    Hi, what you describe is correct. It is called GUI deadlock. It happens because the second command arrives before the firs one completes. It seens that Rhino doesn't like it very much.
    Anyway, that particular one is fixed already, plus several more that a result of a fast clicking on certain buttons.
    Unfortunately the fix isnot released yet - it is quite a rare situation, and the next release will include it. For the time being, please avoid starting a render before the previous is completely stopped/finished.
