GPU Lighting Cache
  • GPU Lighting Cache
    When I render an image, Vray gives me a warning about the GPU lighting cache. Does anybody know how to solve it? Thank you.
    Ziyao
    Dear ziyao_zhang, hello.
    In order to be more helpful please provide us the following information:
    • exact V-Ray version (screenshot of V-Ray > Help > About)
    • exact Rhino version
    • are you using CUDA or RTX render engine
    • currently installed GPU driver version and Graphics card type
    • is it happening in all scenes (even in newly created ones)
    • have you noticed when the issue started to appear (were there any updates etc.)
    Waiting for your answer.
    TS
    Tsvetomira Girginova | chaos.com
    3D Support (AEC,HOU,C4D) Team Lead | contact us
      Hi, tsvetomira girginova
      1. V-ray for rhino 7, 5.20.06
      2. Rhino 7
      3. I am using CUDA render engine
      4. GUP diver version: 512.96
      5. I am not sure about this, I used a random scene and interactive render.
      6. When I start to render a random scene, the issue happened.
      Ziyao
        Thanks for the details.
        Please be aware that on this page is listed which is the recommended driver version - now it is 512.59.
        So, please downgrade to it and share is there a difference.
        Are you able to perform a Production render (to confirm is it happening when performing Interactive only)?
        If you open a new blank scene is Interactive running without errors?
        Have you tried re-installing V-Ray?
        We will need these details to pursue the issue further.
          I perform a production render, there is no error message. However, I have another problem. The cosmos does not load. I follow the instructions and download the latest version. I cannot find cb log in "...". Thank you.
          Ziyao
            Hi again,
            let's solve Cosmos now.
            First you could try this suggestion.
            If the issue persists, we will need your cb.log & config.json (both located here: C:\Program Files\Common Files\ChaosGroup\ChaosCosmos).
              I try to stop and start the chaos cosmos, but it does not work, And I still cannot find cb.log and config.json
                from the screenshot is seen that you are looking into a wrong direction.
                As mentioned above, there are in C:\Program Files\Common Files\ChaosGroup\ChaosCosmos
                Please don't miss Common Files (this is the difference).
                I will open a ticket for you now, where you can send them.
                  Now I saw that you already have an opened ticket ( #4034 ) from last night and Aneliya has answered you today.
                  Please continue the process there and let Cosmos bright up your work again.
