Grasshopper area light dimensions represent the radius not the width/height as UV inputs should imply...
  • Grasshopper area light dimensions represent the radius not the width/height as UV inputs should imply...
    I've noticed that the area light UV dimensions are creating a light twice as big as I would expect - I've plugged a slider set to 50 into both U & V inputs but the resulting light is 100mm square.
    The tooltip says nothing about a radius... and that would only really make sense if I was using a circular light and only then if the input was a radius not UV...
Name:	2022-07-11 Area Light Size.png
    Hello paul-twoatsix ,
    You are right, the values set for the U and V size of the Rectangle light in Grasshopper are equal the half of the Rectangle's width and length, unlike the Rectangle light in V-Ray.
    Thank you for your feedback. We'll take it into consideration.
    Kind regards,
    Iva
    Iva Mancheva
    V-Ray for SketchUp | V-Ray for Rhino | QA
    www.chaos.com
