My wallpaper wont render in scene, it only shows in rhino
  • My wallpaper wont render in scene, it only shows in rhino
    When i try to render with perspective my wallpaper wont show up in the render.
    Dear victorgregers_hagethomsen, hello.
    Could you share where exactly is this image added?
    Is there a chance that it is a Texture added to a V-Ray Dome Light, which is set as Invisible?
    Please see the example here.
    Waiting for your answer.
    TS
    Tsvetomira Girginova | chaos.com
    3D Support (AEC,HOU,C4D) Team Lead | contact us
      Dear Tsvetomira,girginova
      Thanks for the swift response
      The picture was added as shown in the attached photo
      i can see it when i render with the rhino renderer
        Okay, thanks, this was helpful.
        This is a native Rhino functionality.
        We could recommend using Background from V-Ray Frame Buffer, which sets the image in a way similar to your wanting, see here.
        It could be easily changed even after a render is finished and is closer to a collage effect.
        If you want to achieve also lighting contribution, you could add image to:Please take a look and choose what is most suitable for your workflow.
          Thanks Tsvetomira
          ill give it a go
          Best regards Victor Gregers
            You are welcome!
              "Settings > Environment > Background and play around with options"
              Nice feature of V-ray: set texture Type "Environment" and Mapping "Screen". This kind of setup works also for dome lights.
                Yes, thanks, Micha!
                I will add changing the Shape to Sphere as a last step to your exact proposal if he wants to follow the wallpaper effect till the end.
