Materials issue
  • Materials issue
    Hi Guys
    I have some issues with the Rhino materials that I converted into V-Ray materials using the converter tool
    I have some objects with the same Rhino material
    I select one of the objects and convert the Rhino materials into a V-Ray material
    I modified the V-Ray materials and renamed the materials
    The issue is that when I select any of the other geometry with the same materials, they have the V-Ray materials but with the old name prior to re-name the material. And that material is not on the UI because I already renamed it
    V-Ray 6 current released version
    Click image for larger version  Name:	2022-10-12_11-30-08.png Views:	0 Size:	632.4 KB ID:	1162150
    Also, when I try to edit the material using the Edit button in the Rhino UI, it won't take me to the V-Ray UI
